I had my rear shocks rebuilt by pioneer performance --apex special on website new spring and tuned for rider. I just got "Nelly" put back together and she still does not rebound all the way back when you compress the rear. I can lift it 1-1.5" higher and slow rebound .Is this common ....clicker is backed out 5 turns and springs are set on hard... Please help!!!
			what you NEED top worry about is the correct ride height with you on the sled
			Yes Pioneer did send the gap setting w/ the rider on it ..I believe it was 25-30mm for the rear. It does not respond like I would of thought. I run  w/ 2 other apex's rtx and they seem much more responsive..And they are STOCK nearly same mileage and rider weight.
