SRX700Andrew
Last year I installed a 2000 SRX engine in my ’99 SRX. After installation my tach would not work and my hand warmers would not heat up as much as they should. I’m wondering if the new ignition could be the cause of my problems. I checked the part #’s and they are different for both the hand warmers and tach from ’99 to ’00. Does anyone know if this could be the problem? I don’t want to buy new parts and find out that this is not the problem.
the hotter ignition is the reason....i think there is more to....did you change the CDI???
SRX700Andrew
Yep, changed all of the electronics when I installed the new engine.
