suspension setup after shock rebuild
BLUEBALLER
Manitoba
Anybody adjust their suspension according to the tech pages? Did it make the sled corner flatter? I'm getting a bit of inside ski lift now, and I'll be setting up the suspension this week. Just wondering if the current specs worked for you or not.
thanks
BB
if you are gettin inside ski lift decrease the weight transfer some, or loosen the center shock a little and pull up the limiter straps a little, or tighten the rear spring a little. All will help
