oil flow
lowellt
milwaukee,wi
my srx was on its side for maintenance and the manual says that the oil line should be bleed whenever this happens. now the oil tank was full at the time so.... most likely no air got in the line from in the tank.
can i just run pre-mix for a tankfull to be safe???what ratio?? thanks.
its not hard to bleed the line. in between your pto and center carbs there is a phillips screw all you need to do is loosen that up all the air will come outta the line sometimes you might need to start the sled.replace screw and your done its a 2 min job for a sense of security! but if you want to run premix 50:1
