heat in clutch
Snowbear
Barrie Ontario
guys, what is the best way to put some pressure on my belt without changing the weights? I had an rpm issue and i took 4 grams out of the tip, yes runs faster but now I am getting lots of heat in both the primary and scendary clutches. 99Vmax 600, 8DF weights, 4 grams in first hole. w-y-w spring with a brown secondary. my tach is a little off but when i measure with a hand held tach sled maxes out at about 6500 rpm. engagement is fine.
