Bought a used torque limter and looking for a pic or some info on where and how it mounts.
Concept Carbon
it mounts behind the secondary and kind of between the clutches to the case. The u shape braket mounts to the case and the other braket mounts to the frame bnetween the clutches there are 2 holes on the frame already. Good luck
make sure to use loctite. the 2 small allen bolts go into the case and the hex head bolt go through the fram to the braket make sure to put the u shape braket with the welded on nut towards the carbs so you can get the bolt in easyier .
