yamahaulinass
i have a enticer 250 single cylinder and i cant get it to run on its own it got a choke like lever on the right side what is that for? it goes down to the oil tank is that the fuel/oil shutoff? also any one know what the specs on the bottom bolt on the carb? it has like a diaphram thing and it has a bolt on the bottm on the carb>>> how many turn is it to be out? thanks for any info
Yes, fuel shutoff.
Spec are 6 full turns in and then use the sight tube to adjust. I find that most end up 4-5 full turns in. This bolt adjust the fuel level in the carb. Be sure to set the jam nut or it will fall out.
yamahaulinass
ok
is that fuel shut off supposed to be flipped up for the gas to be on? or is it tobe down for it to be on?
sandmanmike1
Do you want a good deal on a complete for parts? I have a 78 250 Enticer that I was in the process of doing a Mikuni Carb conversion on. I think it needs a set of rings. Will sell very cheap.
yamahaulinass
parts
no i working on this for a freind can get it to run on its own aint gettin gas
down is the run position.
