2000 SRX warning lights.
averagesleder
Niagara,Ontario,Canada
Started my 2000 SRX 700 yesterday and the water temp gauge flashed twice. I looked in the service manual and it says the condition is Overheat and to fix it I need to reference the cooling system chapter.
So then I looked here:
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/SRXWarningCodes.htm
at the warning codes it says the problem is open or short circuit.
So what's the first step to figuring out these problems that the light is telling me.
your reading it wrong,you have a grip warmer or variable switch problem,you got to read the flashes to the right not the number to the left.
