stock pipes
No, I wouldn't put the SRV pipe on your triple, you will lose power. Check the Tech pages there is a few little things that will get you more hp. Reed spacers, reeds, peeling one layer off your head gasket or taking the middle piece out and gluing the two paper gaskets together. A good port job would get you 10-12hp.
A good clutch kit will give you more performance (do a search).
