2002 SRX Low Spark ???
bluedevilblacky2k
Southern Maine
I have 02 srx with 10k on it just cleaned carbs new power valves etc. At idle he mag cylinder seems to have low spark. When give a little throttle every thing seems fine. When I pull off the plug wires on pto and center there is quite a differance then when I pull off the mag wire. Any thoughts???
Check the plug caps. Remove the cap from the coil wire and then you can swap them between cylinders to see if the spark issue moves with the plug cap. Remember on the 2000-2002 SRXs you can't move the coil wires between cylinders as they spark independently of each other for their specific cylinders.
If you still have a spark issue on the same cylinder time to test/change a coil.
