russellrox
The machine I am buying is a 98 srx 600, wanting to make sure the carbs havent been played with so I need the base stock settings for the carbs. I am going to be cleaning the powervalves while i'm at it, also gonna try to make sense of the adjustment procedure without removing the exhaust manifolds. Also do you need to rejet with just a mbrp can on stock pipes, owner said it was not nessesary. Want to make sure I will have no lean conditions. Thanks.
Look in the snowmobile Tech section on the home page. A ton of information there. Just click on technical pages then snowmobile tech then stock settings and look for your year, model
You dont need a jet change with a aftermarket silencer but I would leave the stock one on it. The stocker makes more HP
