viperk30
I don't have a manual and I am attempting to change tracks. Will the clutch side drive axle bearing come off over the gear for the speedo? I had a puller on it and it was moving good until I got to the speedo gear. Thanks for the help.
SWEDE
That gear has to come off first, I also suggest you put a dab of anti-seize on the shaft that the bearing rides on and the set screws.If you ever have to remove it again it'll come off by hand and you won't potentially mess up your bearing with a puller either.
viperk30
Thanks for the help.....
I appreciate your time.
