Apex skis on SRX
ReaperSRX
New Liskeard, Ontario
My dad put a set of Doo pilots on his 2008 Apex last year and i wan't to try out his stock skis on my SRX. Do can i use the stock SRX rubber or do i need to get a set from an Apex?
I tried it....when I took the stock skis off my Attak. I used the rubber from the Attak ski., since it is flat on the bottom. It you look at the SRX rubber, there is a lip that hangs over the fron end of the ski shoe, so it is not flat. I took the Attak skis off as it made the SRX sit 1" lower up front, due to the Apex/Attak skis being saddle-less. That SRX is already low enough up front.
--Steve (O.C.)
Thanks for the reply. I have viper shocks on the front of my SRX so it sits higher and i wouldn't mind the 1" drop to keep my centre of gravity down a bit. I will pick up a set for and Apex.
