Clutch Adjustment
watersuper
New Hampshire
How do you adjust the clutch for center to center spacing. Do you have to loosen the motor mounts? If so, what is the easiest way to do that?
Do you also need to set the distance from the pimary to the secondary? If so, is that also done by the motor mounts?
