Help installing 3.5" risers
laketom
Laketomahawk,Wi.
Looking to install 3.5" rox risers on 02 viper. What parts and part #s for cables & brake extension do i need? and any other unseen problems i might encounter. thank-you :rocks:
dont forget to recallibrate the oil pump after changing the oil cable, after changing the throttle cable, after bleeding the brake reservoir, after changing the brake line hose, but before you put the carbs back. while they are out, clean em up. not necessarilly in that order
bar risers/ cable length
good info mr sled, according to info i have been presented with, stock cable length is model specific. i would much rather spend a little extra to know ALL cables work properly as opposed to try to relocate and hope for the best. think of it as a helmet for your sled. one bad "turn" could lead to another.
