srx 2001 700
cleancut
canada
Could anyone tell me if there may be a simple solution, or component to check on my machine...the grip warmers stopped working, but my thumb warmer still works. I traced the wiring and it looks O.K. I know this may seem funny but they sure do come in handy...in -20 weather...any suggestions would be great.
welcome to the site...
start with the easy,get a multi meter and see if you got voltage at the plug,going to each grip. we'll go from there..
Usually only one handlebar warmer burns out at a time, they are in a closed circuit so they need each other to complete the circuit! A piece of the warmer element usually burns out! Causing the circuit to be broken an easy way to check is with an voltage tester or a 12 volt battery connected to each warmer individually!
