primary cover alignment
the tree man
winnipeg,manitoba
2000 srx.Pulled the primary clutch cover to do a spring and forgot to mark it.Where do I find the "x" on the sliding sheave to align with the cover plate?
One X is located on the inside of the clutch cover. The other X is on the spider, close to the sliding buttons.
Its probably covered it belt dust, clean the spider up with a rag, and the back of the cover.. You will see it.
