93 Exciter air filter???
BarneyMN
Minnesota
I was doing some work on the 93 SX and found that the air filter that goes in hood over the intake was very,very brittle! I went the remove it and it just crumbled. Any Ideas what to use to replace it with? or anyone have a spare filter laying around? I couldnt find it on the parts fiche but like everything else its probably not sold anymore......
I have a 91 exciter so not sure if it is exactly the same but the foam filter that goes around the main filter in a shop vac fit perfectly in mine, my old filter did the same thing, touched it and it just crumbled away, not sure if it was the cause but I noticed it right after the pistons burned up.
