I have the front drive (9 tooth) out of my 98 SRX Mountain out and i want to put anti-ratchet drivers in.
If i put the 8 tooth anti-ratchet in will i gain any clearance from the rails to the drivers or do i still have to buy the anti-stab wheel kit from Wahl?
Thanks in advance
Thanks in advance
staggs65
the 8 tooth is smaller dia. so yes you'll gain clearance, someone else will have to chime in on wether its enough to eliminate the anti stab kit though, on a side note, you may need to change your gearing with the 8ts depending on what riding you do
ottawaair
Yes, gearing will need changed, or it will be lower. Just got mine together with th 8 tooth, I don't have anti stab, I think it will be ok. I did however modify the plastic rail tips, cut back a little & rounded them off. looks like it will clear to me, but for 100 bucks you'll never have to worry about it.
pipdviper
I had to cut the teeth down on my 8 tooth drivers to clear the rails. I read you can cut down the rails so they dont hit.
