ReaperSRX
I need to remove to accomodate Ripsaw for my 2000 SRX 700, i removed my skid plate and the rivets that hold the protectors, they seem to be loose but can't remove, did not want to force just in case, i have not remove the drive axle yet, any advice.........Reaper
the protectors are stuck in the hole on the top side of the tunnel, they should just pull out.
ReaperSRX
I don't doubt you but seem to be pretty stuck in there, do you think i should wait until drive axle come out then try to "yank" on them, beause it seems the track it getting in the way...........Reaper
ya, just incase they are different , you will get a better view then...
