Can someone tell how this setup will work out for me 8BU-00 4.5 tip .8 middle
stock 47 helix wrapped at 80 with silver spring
rpm wise? need help dialing in for drags, it's a 2000 SRX 700, 200lbs driver, 21/40 gearing everything esle stock
Every sled is different, So you'll have to get out there and try it to be sure.
YAMMIEGOD3:16
GOOD ON THE WEIGHT,S GOOD ON THE GEARING, DON,T LIKE YOUR HELIX, UNLESS YOUR RUNNING LONG HAUL. 3:16 (yammie tony)
I tried this setup and is spot on for rpms 81-8200 launch and 84-8500 WOT and holding, max speed in 1500ft was 110mph on dream-O-meter and climbing but run out of room. I took 3 runs back to back and I'm hitting 90mph at 660ft every time, STILL NEED TRACTION!!!!!! as I spin for about 100ft in 660ft.
I don't have a 51/43 helix to try yet but will that gain me any in 660ft and also I'm running 21/40 gearing, I'm going to try stock gearing see what it does just curious as to what the outcome will be
YAMMIEGOD3:16
STOCK GEARING IS 23/38. THAT GEARING WILL PULL FOR A MILE. YOUR SLED FEELS GREAT IN 660 BECAUSE OF THAT 21-40 GEARING. THATS PERFECT FOR 660. YOU WANT TO RUN ANY FURTHER, GEAR UP. 3:16 (yammie tony)
