00sxrjoe Active member Joined Nov 22, 2008 Messages 1,149 Age 43 Location Maine Dec 19, 2009 #1 I have a 98 srx 700 with a warn light . ... I look in tech and I can not find the codes again, any one know what it is?
staggs65 Moderator Joined Jan 18, 2009 Messages 5,524 Age 50 Location Sabattus, Maine, United States Dec 19, 2009 #2 you need to post the pattern
daman New member Joined May 2, 2003 Messages 10,569 Age 55 Location Bad Axe,Michigan Dec 19, 2009 #3 staggs65 said: you need to post the pattern Click to expand... x2......
Y Yami600 New member Joined Jan 3, 2009 Messages 56 Age 47 Location Canada Dec 19, 2009 #4 Under the Tech section in the TY homepage go in miscellaneous and you can see the warning light code for the SRX.
00sxrjoe Active member Joined Nov 22, 2008 Messages 1,149 Age 43 Location Maine Dec 19, 2009 #5 one long then 3 short its the temp sen
