bravo-guy
Hey guys I finally got my main jets and now I need to put them in. I don't know much about carbs, as in how to change jets. I also need to adjust the air screw, I believe this is on top of the carb? Looking at a microfiche parts diagram, I can adjust that without even removing the carbs. Does anyone have step by step instructions on how to do this?
bravo-guy
And what side is PTO and MAG side from sitting on the sled?
can you locate a service manual? it would help you if your not fimilare with working on this stuff, sitting on sled pto is the far left cyl(by primary clutch)mag is far right cyl by pull cord.
bravo-guy
well guys the jets are changed and the air screw adjusted, sled rips now and runs like a scalded cat with the pipe/clutch kit, acceleration is really good. And I should have 100% stock reliability according from people on here
