travpeterson
I have a 92 Bravo;it starts and idles fine;but dies as soon as it is revved up;Carb has been cleaned.Can anyone tell me approx.fuel pressure it should have;and how big a pulse from the crankcase;if I put a vacuum-press.gauge on it.Thanks
Try cleaning out the choke plunger in the carb. I had a similar sled do the same thing. It was loading up with fuel and would run terrible because the gunk on the choke plunger was causing it to stay partially on.
