what class would i be able run in?
madzx2
Osceola Wi
i have been reading the rules for the nssr and cosdra and im having a hard time figuring out what class i would be running in. i have a 00 srx 700 ported, aftermarket heads, and reeds.
improved stock classes as long as you still have stock carbs, suspension, and retains its stock appearence along with a few other things . google ISR drag rules and you might find more detailed technical info. good luck
I don't think you can have the aftermarket heads to be in improved stock you probably would be put in pro stock in the NSSR.
even in improved stock and stock you better know what your doing. aftermarket heads will put you in prostock which you better have some money stuck into it
