lakeofthewoodsrider
There have been quite a few posts on this if you do a search...in a nutshell:
Valin has done dyno testing and was generous enough to share his findings.
Valin says it looses horsepower on his 780.
I have them on both of our SXs[redheads] and they work very well.
I had one on my 2002 SRX and never saw any improvement and once I read Valin's info I removed the boost bottle for this season.
Don't know why they wouldn't work on the SRXs but have to go with the facts!
JM.02c
JM.02c
lakeofthewoodsrider
Thanks sideshow, How is the ice and snow around you? Was running on L.O.W. around 12" of ice. I was getting some good speed. but my speedo key bust....I think I have to dig it out of the shaft?sideshowBob said:There have been quite a few posts on this if you do a search...in a nutshell:
JM.02c
We have approx 12" of ice...trucks + ice shacks have been on the lake for about 4 days...short ice road in the area is open as well. We have only about 6" of snow on the ground for now. The deeper trout lakes in the area are probably not quite ready for riding on yet, but soon.
mikeast
would a boost bottle help more if you were running aftermarket pipes and reeds? dynos dont lie, but waunder how throttle responce would be compared to stock guess i got to buy one and try it out
mopar1rules
staggs65
pretty sure VALIN's 780 has both along with heavy porting and bigger carbs and per mopars post 5-7hp losswould a boost bottle help more if you were running aftermarket pipes and reeds?
valin
staggs65 said:pretty sure VALIN's 780 has both along with heavy porting and bigger carbs and per mopars post 5-7hp loss
It's not all that heavy.
livewire_101proof
any posts ive seen so far says they do really well with non powervalve motors but with powervalve motors dont do much and actually loose after like 7000 rpm or something like that, cant remember the rpm # but it was in the higher rpm range.
