76 srx
rambo3010
dresbach, mn
can you still run pump gas with this set up. 79 srx motor with 76 pipes 42mm carbs with 1976 18.5 cc heads.thanks rob.
With stock 76 heads...premum gas is fine...
Pipes and carbs make no diff.
High octane = less HP.
LET ME TELL YA WHAT, YOU RUN TODAYS PUMP GAS CRAP IN A 76 SRX YOUR ASKING FOR BIG TROUBLE. PUMP PREM TODAY VS 33 YEARS AGO I WOULD SAY THERE,s ALITTLE DEFFERENCE. GUESS YOU DID NOT SEE ALL THE POSTS ON HERE LAST WINTER OF PISTON FAILURE, BUT HEY, AIN,T MY MOTOR. 3:16 (yammie tony)
i do agree higher octane = less HP
i also agree that gas from 30 years ago is better.
i sometimes mix the two. seems to start easier and i can read my plugs.
if i run premium in my buick and the 1987 computer chip it sounds like ball bearings in a coffee can. a new chip has to be burned for todays gas...
I may be wrong today..but...92 octane is 92 octane...I think...
Around 2003 +/- my son won the Mosport 125CC kart champion ship...42HP....13,5000 rpm..Euro..racing engine...the competition all ran race fuel..we ran Sunoco premium...about 110 psi +/-
Over 100 mph...
No problems...vertex pistons...
Gas then was not the same as gas now because we have no lead now. A stock 76 SRX needs to run at least 100LL Av gas or any average race fuel. It needs the octane and the lead. A two stroke motor today with only 110psi of cranking compression would certainly be fine on 92 Premium, as RJH has proven.
