Uber-Moto
So, I mounted a 2-up seat off a Venture + backrest and hand holds.
The seat has a harness in the rear for OEM heated grips. However, at $250 for the whole kit, I opted for a DIY kit ($35).
The kit I bought included two elements which wrap around the passenger handholds. A Hi/Lo switch is also included - with an in-line resistor. Everything tuck's neatly away under the seat. The heated vest is spliced into the same Blue wire powering the heated grips.
Tap into the Blue wire for AC power and use any bare metal on the sled as a negative point.
As per the 12v DC outlet - tap into the brown wire behind the headlight. Use any bare metal on the chassis as a ground.
I drilled a large hole next to the driver heated grip thermostat and mounted the plug. This allows me to run a short wire into my GPS device.
