2000 SXr700 with Bender Pipes
middlman
Lakeville, MN
I have installed my bender pipes and 150 mains (plus move center needle to 4)..... The plugs appear a bit rich even at -3 deg F.. Does anyone have another setup like 147-148 jets with a diff needle position than stock? (I know I can play around and plug read but thought I would ask)
I am adding 89L wights with 2.4g steel rivets and a 51/43 helix this weekend... I can't stop spinning and my clutch seems like it is over shifting and spinning on the belt.. (didn't feel the sheaves but I am sure they are hot) I was running a hauk clutch kit primary and secondary....
Thanks!
Steve Campbell
pilots 47.5
mains 150
needle stock middle
stock weights 8df-10 tip 4.5 gram, mid stock
spring bender gold
helix bender 9960
sec. spring stock@80*
bob
You need 14.5 mm rollers with the 89L,s. Your also gonna need heavier rivets cus the sx-r uses a stiffer primary spring.
