Phazer3lakes
Started the sled this morning and found fuel on the garage floor. Looks like fuel is leaking from the left carb. Sled smokes a lot and won't stay running unless you hold the throttle open. Any ideas?
Sounds like you have a needle and seat not seating or mabey a little dirt under the needle either way the gas flow is not stopping when the float comes to the top.Pull the carbs and see what's going on.
Fuel line may not be connected , or crack in line....
Phazer3lakes
Gas Leak
Thanks for the info. I don't know how to remove the carb so it looks like the dealer will have to do it.
