sirquentin
Hey again, I have my SRX extended to 151, have aaen triple pipes, porting, spacers and cold air intake kit. Does anybody have a good clutch setup they use in the mountains. I still have the stock clutching, but I have a Comet 4pro on the way as well. Any info would be appreciated.
S
srx_eh
Guest
Hello from Calgary to the Fort,
I'm running a MSRX as well down in southern alberta, most of my riding is in the foohills. This is my current clutch setup and seems to climb well;
136X2" track, 8Tdrivers
primary: 8DN-20, 2.4g inner, outer empty, stock rollers, YWY 2shims (4.2K engage/shiftout 83-8400rpm.)
secondary: stock spring(red), 70deg. squeeze, 54/44 helix, 8DN belt
gearing: 23/39 (1.90 ratio), ...I do some flat land as well, ...you may want to change your gearing to 2.00-2.10 if you spend most of your time climbing.
SRXtreme
1st recommendation is throw them Aaen pipes over your left shoulder...........SRXtreme
