dirtjumper895
Can i do it in my sled? I seem to foul 9's was thinking a little hotter may help keep the unburnt fuel burning....
Mods are,
Speedwerx Triples
Speedwerx 12:1 Billet head
93 octane running Amsoil Dominator
Oil pump 20.8 mm
160 MJ 50PJ Needle at 3 or 4 (cant remember)
Plug Chops looked excellant
Carbs are clean
This sled is my mountain sled, lots of hard running, I do fan the throttle to keep motor cool.
Biggest worry is cooking a hole in the top of my pistons from the hottter plug.
Try it, or stick with carrying a couple spare 9's?
Thanks!
Mods are,
Speedwerx Triples
Oil pump 20.8 mm
Carbs are clean
Thanks!
dirtjumper895
Oh yea, i run flowrites in the dash, no underhood air. Stock airbox.
jasonlmrx
i think you are supose to run BR9ECS in a stock sled.. i dont know if it makes a diffrence or not.. i run BR9ECSIX... just saying.
dirtjumper895
The "C" only signifies that its a 5/8" hex instead of the 13/16" hex... the IX is an iridium plug, and for how i went through them while tuning last year, im glad i didnt fork out the cash for the iridiums... Maybe now that my jetting is close, i should run the iriduims?
dont know how to explain it but the ECS plug is tapered around the the ground strap and electrode, the regular ES is not. Doubt that slight taper would keep your plugs from fouling, but maybe. Plus they are very expensive, ECS plug is almost $7 ea at local shop, compared to $2 for regular ES.
I was told by an NGK rep that ECS and IX are anti fouling. when you look at the ceramic by the electrode it is concaved in by the electrode. Once these plugs reach operating temperature they emit small discharge sparks off the side of the electrode that chews/eats away the carbon deposits that cause the plug to foul before they actually touch the elctrode and foul the plug. Also the IX has a tapered ground strap to help it cool so that preignition does not happen with high ethanol fuels.
dirtjumper895
Hmmm... Maybe i throw 3 BR9ECS's in and see how they work... Did not know about that taper...
staggs65
yep, dont run 8s, also if you like amsoil run interceptor not dominator, dominator is horrible on the powervalvesHmmm... Maybe i throw 3 BR9ECS's in and see how they work... Did not know about that taper...
dirtjumper895
staggs65 said:--------------------------------------------------------------------------------
Why do you say not to run 8's? Im probably going to switch to Interceptor anyways...
8,s are a hotter running plug,,, you don't want to run hotter than recommended....
livewire_101proof
i run the es plugs in mine and dont have any problems, watch hotter plugs, if its too much youll end up melting down a piston. x2 on the interceptor, its made specifically for powervalved motors, as little residue as possible.
staggs65
sorry busy with the holidays but whammy and livewire covered itwatch hotter plugs, if its too much youll end up melting down a piston.
mod-it
If you're fouling plugs, jetting still possibly isn't right. Or, the oiler cable is stuck or pulled apart at the joint. My oiler setting is at about 20mm (probably could adjust this, seems pretty rich), so I don't think the setting is the problem. I had a problem with fouling plugs for a couple of rides, until I noticed that I had pulled the oiler cable apart at the joint during carb cleaning and re-installing the air box afterwards. It would foul them when running at low rpm's, like when I was putt-ing along looking at a line I wanted to hill climb. Fit the joint back together and changed the cable routing a little bit around the air box, and no more fouling. I change my plugs every season, but just for maintenance, never foul them. I'm running BR9ES.
dirtjumper895
How bout a weak coil?? The reason i ask i i can put the "fouled" plug into a different cyclinder, then that plug is just fine and fouls a different new one...
I am thinking about testing my Mag side coil to see if its out of spec...
staggs65
yeah check that and the plug cap
dirtjumper895
Before these troubles, my jetting was spot on. ran 1500 ish miles last year, didnt foul 1 plug. This year (same temps) and ive been fouling plugs. Ive got the sled melting off, eating some chilli, and will go out and check coil specs... I see there is a primary and a secondary coil spec.... Whats the deal here and how do i test each? I have a pretty decent Fluke multimemter so i can check ohmage...
staggs65
whats your email i'll send you the service manual, it should be in there
dirtjumper895
jclevine@mtu.edu.... Thanks a Ton!
staggs65
just sent it, let me know if it went through, been having some trouble with a few peoples emails
dirtjumper895
Tested the coils... Here's the specs
Mag Side (one i was fouling)
Cap 5.06kOhm
Primary Circuit .8 Ohm
Secondary Circuit 6.34 kOhm
Center
Cap 5.17 kOhm
Primary .5-.6 Ohm (meter varied b/c only had 200ohm setting)
Secondary 6.33kOhm
PTO
Cap 4.56 kOhm
Secondary 6.17 kOhm
So what yalll think? I have an opinion, but figured i'd let the more knowledgeable speak first.
Cap 5.06kOhm
Center
Cap 5.17 kOhm
Secondary 6.33kOhm
PTO
Cap 4.56 kOhm
Secondary 6.17 kOhm
