91phazer hotgrips
JDlefturn
Mid MI
The hot grips on my son phazer stoped working, there is no power at the yellow/black wire,is there a coil just for that wire,I'm gessing that it is for factory installed grips, the ground if fine thanks steve
Yes there is a seperate coil for the grips. There is a connector near the motor where you can check for power to eliminate any wiring problems. There is a wiring diagram in the owners manual if you have one.
Thanks for the help,don't have a manual,but I got it the wire was broke in the tape at the Y where the bars bolt up must of happen when the sled was new and just give way because the tape wasn't broke,5seconded fix 1HR to get to it
