anyone know if a 01' sxr trailing arm will fit a 01' srx?????
In a nut shell,,,,will it bolt up? sure but the caster and tube length will be wrong/different,
a SRX has a short V tube(7" travel) 23.5 deg. T/A
a SXR has a short R tube(9" travel) 25.5 deg. T/A
if using a SXR T/A on the SRX you would need to use both because the caster is different on the SXR T/A.
gild
ur right i stand corrected, it's a R T/A,,so just the caster would be different.gild said:01 SXr has the short tube
some '01 and new models used the new ski and low profille saddle with a lower ski saddle/spindle mount location. this new ski/saddle assembly required a new spindle and ta with different spindle tube dimentions,thus the M stamping on front.
