srx..no power..tach/headlight/taillight
viperdougc
Arnprior, ON
My buddies 2002 SRX has no tach, headlight,tailight. The sled is running great. The usual wire harness check was done and everything looks good. I did see that the relays can go and produce these symptoms. Could the stator be done??? Any suggestion would be appreciated.
that sometimes happens to mine if I park it outside overnight and there was humidity in the relay. If you disconnect the relay and warm it up, it should be fine.
