Venture low speed bog
mdkuni
Houghton Lake, MI
We have a 00 Venture 500 XL fan that has developed a low speed bog. Sled has about 6,000 miles on it. Anything less than 5,000 rpm's if you open the throttle it takes about 2-3 seconds before the RPM's will climb. It doesn't stumble but is just slow to respond.
Carbs have been cleaned, twice. No issue there. Compression check was done and both cylinders are in spec. Plugs have been replaced. The top end speed is fine.
Any ideas?
