Speedo issues
mtnmaxman600
Wisconsin
I was out testing my 98 SSX project sled and noticed that the speedo doesn't seem to be working correctly it only goes up to about 50 mph and when you stop it takes about 10 sec to drop to 0 from 25 mph. It had a new cable and drive key the 90 adapter is orginal and so is the speedo head. When I bought the sled the cable was missing and the key was broken just wonder what the problem could be. Any thought let me know.
there is 3000 miles on it. I thought that I would take the cable off down below and run it with a drill and see how it does.
Speedo
You should be able to pull the cable from the drive end and twist it fast enough with your fingers to see the needle move. It should not turn hard at all. Has the speedo ever got water in it?
I found a new speedo head for 35 bucks and install that into my cluster and tested it today and it works fine now.
