T.S.U.Filmz
PM sent
livewire_101proof
never tried ones from other brands so im not sure about the mounting but the length would be fine. Stock is under 14", and vipers and other newer yamaha's have almost 17" eye to eye. be sure after your done to adjust radius rods for your camber or handling will not be quite rite, i made that mistake once, took me a while before it dawned on me. Easiest way i found is to take off the skis and run a bar straight through both spindles. the only way it will do it is if everything is dead center. then i cambered out just a hair before tightening everything up, i also toed out the skis about 1/4" from front to back but that stuff may change a little depending on how each person like the machine to handle. makes a world of diffrence. you wont be dissapointed.
