SRX Belt
Gagt518
Albany,NY
I know this is a newbie question but how would i go about changing a worn out belt with a new OEM one? Thanks in advanced
If you get a 12 mm socket and ratchet you can put it on one of the three secondary bolts that hold the helix in place. Make sure your ratchet is on tighten and rotate clockwise while pushing in. This will open your clutch making the belt easier to remove repeat the steps to install a new one
push in and turn the clockwise on the secondary clutch. pull the belt over top of it. and work it around the clutch.
Just put your hand on the area that has the three bolts and push in/turn clockwise, and the clutch will spread apart and you can slide it on/in. Put the belt around the primary first when installing, and take the belt off of the secondary first when uninstalling, it is very easy once you do it.
Just so you know(apparently the previous owner didn't!), unless the belt is junk and you are going to put a new one on, for sure, the next year, never store the sled over the summer with the belt on. It will stay in that shape, and be like an oval. Plus it is easier to move around without a belt.
