low rpms
jesseSRX
Cross Plains
My srx has a 53/43 helix 70 wrap. When running wide open the rpms do not exceed 7900. I'm not sure what type of primary set up is on the sled. Would changing the wrap raise the rpm's?
what year srx and what weights are you running?
You gonna make things worse messing with your secondary. If you have a clutching problem not reaching RPM's its more likely your primary. Your secondary should be green @ 70, if it is, i would leave the secondary alone and look elsewhere.
Did you adjust your power valves or check for broken or pulled through cables?
Green spring. Power valves are good. I think I have bigger problems. 1 cylinder doesn't seem to be firing. I change the plug and it fouls again and again.
