Damon259
Hey fella's, I have a 1995 Phazer Long Track that i bought last winter and has been working really good for me. It has plastic USI ski's on it at the moment, but didn't last long. The end of the ski loops broke right through the plastic and now its only the top of the ski loops that is holding it on!
So would anyone be able to send me a link for plastic ski's that would fit my Phazer?
Hope you guys can help!
Thanks!
Thanks!
JordanHall488
I use kimpex skis, they have worked great for me so far, i think iv had them for 4 years. these ones say vmax, so i dont know if they would fit..but they look just like what i run http://cgi.ebay.com/ebaymotors/Kimp...79344654QQptZSnowmobileQ5fPartsQ5fAccessories
chilli
with some tricky engineering, you can make C&As work.
I took my CAs off my srx, to test with my exciter II
What Im going to do is cut out the metal saddle from a set of extra metal skis from the exciter, and bolt those down to the bottom of the CA mount area (going to countersink some pan head bolts in the large keel of the CA Razor, under where the carbide sits) once metal saddle is mounted to skis, then use normal exciter rubbers that already fit the metal saddle
then the ski bolt holds all in place
again, all theory at this time, but I tested and took measurments, and will work...just need some grinding and cutting
Damon259
Thanks Jordan, them Kimpex ski's look good. I love to have plastic ski's on them old phazers i don't wanna go back to metal ski's.
i have arctic cat skis off a 98 zr 600 on mine you just gota ues some washers or make some spacers
PhazerII72909
Yeah, my phazer II has arctic cat skis on it.....not too proud of that. haha.
jwurl
I have a set of Red USI skis that have the upgraded stainless loops and fasteners. They came off a 88 Exciter. $150.00 Thanks, Jeff
