One gram Washers
WNR18
Tisdale Sk
An earlier post mentioned an SRX over-reving on the top. Turk mentioned one gram washers peened under the 4.5 gram rivet. Where can a person get these washers? Are they Yamaha only? Is so , does someone have a part number? Thanks
I just used some 6mm i.d. flat washers, used 2 on each tip, added about 1.5 grams, but had to grind off the area that hung over the roller surface, so now added about 1.25 grams in the end, yet to try it out.
