srx chassis on vmax?
Trent Millard
SK Canada
I have a 97 Vmax 700 Xt that I totalled off the chassis. I have a bulkhead & tunnel from a SRX 600. Do you guys know if all my components(suspension, engine, chaincase, etc) will fit on the SRX chassis? Thanks.
Absoutely
But you'll have to change the front aluminum cast section of the bulk head. Those parts are going to be different where the front motor mounts are and also the front shock mounts. Other than that there will be some other small things later on such as muffler brackets and so on that you'll need to change. What part of your current chasis is damaged???
Madmatt
