1998 SRX Spark Plugs
Big Willy Style
Chicago
Hey guys what is the best plug to run in a 1998 SRX 700. I am having problems and fouling plugs within the first couple of minutes of the sled running. I am trying to figure out what the hellis going on but getting expensive with buying new plugs! Thanks,
BWS
The BR9ES has a standard non projected firing end and traditional height ground electrode. The firing position will be set at about 1.0mm from the combustion wall.
The BR9EYA has a slightly longer firing position set to 2.0mm and has a V-grooved center electrode for better ignitability and increased performance.
The BR9ECS also has a standard center electrode (non V-power). But it differs in that it has a much shorter and stronger ground electrode that helps to prevent ground electrode failure, especially in high rpm small engines that have a lot of vibration and bad harmonics. It has a much lower firing position at only .3mm.
If an application calls for the BR9ECS I would suggest ONLY using that plug as I have seen the BR9ES/EYA have ground electrode failures when substituted. If the applications for the BR9ES, then the BR9EYA could be used as a better performing option (so long as the engine has clearance for the extra 1mm of projection) as could the BR9ECS (especially in a racing application to be sure you won't have any ground failures, or in a forced induction or nitrous application). Hope this helps, thank you.
Best regards,
Brandon Peeler
Technical Support Representative
Aftermarket Division
NGK Spark Plugs (U.S.A.), INC.
46929 Magellan Dr.
Wixom, MI 48393
