I have 97 Yamaha Vmax SX 700 tripple, i just bought the sled about 2 months ago. I've noticed that the sled use more oil than i think it should be.
After going for a 2 hour ride i am needing to fill the oil.
I have filled the oil resivoir about twice now ( Roughly 2L) and have only used about 20 bucks in Gas.
I was wondering if there is like a little switch or somethign so i can control how much oil is being mixed with the gas and where it is located?
http://www.totallyamaha.net/forums/showthread.php?t=54619&highlight=adjust+oil+pump
try using the search i just searched for oil pump adjustment
thanks for the link captn.....
a 97 sx 700 you want 19-22MM on the oil pump spec(gap)
Do these checks in this order;
1st- set idle to 16- 1,7000 rpm's(@ operating temp)
2nd- set throttle end play to 2mm(adjustment for that is here )
3rd- set oil pump cable free play here and here to 19(richer)to 22(leaner)mm
then set choke anytime to 1.5mm
try 20 or 22 and see,where is it at now?????
You want to shoot for 50:1, 1 qt per tank of fuel(12 gals)TrueYammy said:I have 97 Yamaha Vmax SX 700 tripple, i just bought the sled about 2 months ago. I've noticed that the sled use more oil than i think it should be.
