Starter Ring gear bolts for Viper
Millinocket Rocket
Sebago Lake, Maine
Does anyone have a picture of the bolts that hold the starter ring gear onto the clutch or know what they look like? I got some bolts that seem to fit and thread in good, but the holes in the ring gear are a little bigger than the bolt, and didn't know if the factory bolts have a bigger shoulder on them for a tighter fit. No-one around here has the factory bolts in stock. Thanks
i ordered some from yamaha and they were just standard looking button head cap screws , no shoulder. its possible the holes are slightly enlarged from the ring being loose at some point ?
the one i worked on rattled the flywheel loose , so i ordered new bolts and a ring gear. the new bolts were not a tight fit thru the holes in the new ring gear , there was alot of room to move the bolts around in the holes. i assumed that the ring scentered on the clutch not the bolts.
