2001 700 mtn max jetting
leadfoot33
Prince George British Columbia
what the jets should be that would be great to. i run 2000ft to 6000ft roughly -5 to about -20 Degrees Celsius. right now i have 142.5 main jet and 52.5 pilot jet. with 2.5 turns on it. thanks again. its a weird kind of bog like when you just holding steady say at 4500 - 5000 and go wot it hesitates a bit. still to lean?
right now i am testing at 2000ft. i am just basing what it is doing off of what my polaris did, it did this and all we did was richen up the pilot jet and it went away. the bog/hesitaion gets better the longer the sled runs. should i turn the screw back to 2 turns (stock) when i got the sled it was set for 4500 ft roughly riding in revelstoke. it had 138 main jet 52.5 pilot jet and 1.5 turn on pilot screw. thanks
also i would like to find a break down on the carb so i know what all the screws do. thanks. sorry for long thread
i run from 3 to 8000 feet.when i got one of my sleds it had that same jetting with power inc pipes and it ran great but like yours i had a hesitation a 5500rpm where i rode all the time after 5500rpm she went like a bat out of hell.but they say to go up three jet sizes to about 141 mains and you can keep your pilots the same when you put pipes on .did you do a sprak plug test?do you have any other mods?where do you live prince george?
