warning light viper
kuku
Toluca, IL
My service engine light flashes real slow but constant. Its not the power valves as I checked them and unplugged them and got the 7 quick flashes so I plugged them back in and still getting the slow flashing engine light. The sled runs fine and cant tell any real problem but wondering if anybody else ran into this problem.
maybe to low on gaz ..if it keep flashing slow it mean something is going bad ..try to count the flash
full tank of gaz, its really not any of the codes on the tech page, really no breaks in the flashes to give a good count.
if they are disconnected or short to ground it will produce a code ......make sure they are connected
They are connected. I was going to use a ohm meter to measure the resistance to see if I can figure out which one was bad since I assume if one is bad it will make them both not work. If one is bad, would that throw up a code?
yes it will ...go in tech section u have all the code there
