Snoscoot ?'s
vectorboy
Calgary
I just bought two Snoscoots for my boys. I have been through them and both are more or less the exact same. One is a 88 and the other a 89. The 89 flat out rips. The 88 seems to start out strong but then it seems like the power all of a sudden flattens out not like the 89 which pulls to top end. I checked the carbs to see if the mains were different but both carbs are identical and set the exact same.
The 88 has a B8HS plug and the 89 has a BR8HS plug which i don't think should make a difference.
I noticed the 88 had a intake leak around the read cage where a little oil/gas was slowly seaping out. I fixed that but it did not make a difference. I did a compression test on both. The 89 was 120 hot and 125 cold. The 88 was 90 hot and 112 cold. I cannot seem to find a compression spec anywhere.
If i lift the back end and WOT it seems to stay strong all the way through and it seems to get past this flat spot.
Any other ideas ? Thoughts ?
I just changed the fuel pumps around to see if that was it and no change. New plugs gapped properly no change. The funny thing is when i lift the back end off the floor and pin it it seems to almost clear out and the flat spot dissapears, until i put some weight on it the flat spot is there. It has to be either low compression or maybe a clutch issue. Low compression would effect the top end for sure. Its funny how when idling it doesn't seem as strong as the 89.
I have new clutches coming for both of them so that will take care of the primarys. Strange. Cold compression is up at 112 psi. I looked at the belt and it looks pretty good although i didn't measure them yet.
I just got back from riding with my boys on the lake. I noticed if i rode down a boat launch ramp it had it full power and if held to the bar it would actually accelerate to top speed and stay there until i let off the throttle and then it would have the flat spot again. Would compression do this ? Seems strange. I really wonder if this is a compression problem or some weird fuel/oil problem. I'll have to measure the oil pump to and see if it putting out the appropriate amount. Clutching needs investigation as well, LOL
staggs65 said:
seems to me like that would be the difference
Yup.
There is definately a problem there, no need to look any further. It may not be all the problem, but whatever is causing the low compression needs to be fixed, so do that first.
