Maxximum Quick Rods
Canuck
Ontario Canada
Looking for some input on the Maxximum Quick Rods, are they worth it or should I just get the Quick Nuts? Does anyone know how much more adjustment they give you? Their add says the stock rods are only give 7.5mm of adjustment but they don't tell you how much adjustment you get with the quick rods.
http://www.maxxperf.com/Quick_Rods.htm
Thanks,
Ken
I have the original style "quick rods" from Maxximum on my srx.....they are the ones with the "jam nut" style nuts on them (wish I had the quick nuts).......near as I can tell(with no information on exact measurements)....they give you about 10mm more adjustment over the stock rods.....I can only notice a real difference in transfer when I have them tightened up as far as they will go though. However....they were an improvement over stock. I'd say they wouldn't be worth the cost they want for brand new ones (unless you spend alot of time racing) but if you can find a set of used ones for a reasonable price, get them, by all means.
Wreck
